DIY: Inner Tie Rod Removal / K-Tuned Upgrade
3 reading
59K views 30 replies 9 participants last post by  Them Witches
#1 · (Edited by Moderator)
Decided to install some tuned inner tie rods to correct the issues I was having with being lowered.
The tuned are adjustable inner tie rods meaning you can adjust the length to either bring your toe in or push it out getting your tires straight.
It is a common problem for people who lower their cars to have toe problems and to compensate you would either need extended tie rod ends (Moog-ES2382) or shorter tie rods.
The solution to my problem was the latter.
This DIY would always seem very daunting to me as every person I'd heard talk about it made it sound much harder than it actually is.
Plus, to make things more confusing a lot of the info on here is people mixing up the terms TIE ROD (inner tie rod) and TIE ROD END, so you end up being misguided on how to perform this DIY.
All in all, if you have some knowledge of how everything is put together before going at it the job is pretty basic.
So here's a DIY with some helpful tips:
You may be able to do everything from the top but this is how I went about it.
I'm running a cold air intake so you may want to remove the stock air box to clear the room up top.
My header is stock and I still have the heat shield so if you have a race header I believe you'd have even more room.
Unfortunately, an inner tie rod tool (tube kind) such as the ones you can rent from your local auto parts store won't clear the gap from the tie rod to the steering bracket.
Fortunately, once you bend the lock washers a crescent wrench with some leverage will do just the trick.
Remember that you can turn the steering wheel to move the steering bracket from side to side if you need a different angle at it.
If you're able to get your hands on a steering bracket riser (such as the 0857; fixes the geometry of the tie rod if you're slammed) this would be a great time to install it.
Tools I used:
Jack and jack stands
Crescent wrench
Ratchet
10, 12, 19 sockets and extensions
Small sledgehammer
Long pry bar or chisel
Needle nose pliers
and not necessary but to make things easier and faster I used PB blaster, an impact wrench and a cordless ratchet.
1. Jack's front end up. Place stands. Remove wheels. the obvious stuff.
2. To gain maximum clearance from under the car, remove the heat shield under the tie rods (four 10mm bolts) and the mid chassis brace (four 12mm bolts, two on each side).
The two upper bolts on the heat shield connect it to the mid chassis brace and I believe you only need to loosen the bottom bolts as the heat shield can then slide up and out.
3a. Bend lock washers (blue arrow) away from the steering bracket.
There are 4 bends in total that need to be bent back, 2 on top and 2 on the bottom of each washer.
This is probably the hardest part of the DIY; you need to find the right angle and use the right tools which will make it a lot easier.
I used a long pry bar and a small sledgehammer wasn't pretty but got the job done. (3rd picture below)
The reason we need to do this is that there is a thin hex embossed on the nut of the tie rod beyond the threads holding the washer in place. (4th picture below)
If you need new lock washers the part number is 53536-S5A-900 and I provided a link at the bottom of the DIY.
*K-Tuned does supply new lock washers with their tie rods, so if you're upgrading like I was you'll be covered.
:Deadhorse:Deadhorse:Deadhorse
3b. Loosen both nuts (red arrow) on tie rods.
The nuts are 24mm, I used a pry bar against a crescent wrench to loosen them.
I'd recommend using a cheater bar that fits around the grip of the crescent wrench if available.
..Just want to clarify that both nuts are turned regular (left) to loosen as I saw some other posts stating otherwise.
You may want to spray some PB blaster on those nuts to make it a little easier on yourself.
4. Remove the tie rod end.
if you're trying to use the same tie rod end on your new tie rods be sure to loosen the locking nut (clockwise, away from the tie rod end) before popping the tie rod end out of suspension.
PB blaster always helps.
mini DIY on popping tie rod end.. as I'm sure there are plenty on here.
remove nut. (19mm)
flip nut. (install flush with the end of threads)
bang nut. (with a hammer)
done. :thumbs up:
*if it's been a while, you may mess up the threads this way. at this point I'd recommend a tie rod separator tool of some sort.
5. Remove the tie rod assembly. :aww yea:
6a. All that's left is to do everything backwards and reinstall everything.
torque tie rod end to 40lbs as well at the tie rod if you are able to.
6b. Upon reinstallation, bend the lock washers around the steering bracket as they were before. (as seen on the right lock washer below)
I did this again with the hammer and pry bar, and came at it from the sides.
All done looking like a diamond in my dirty-ass engine bay. :Giggity:
7. Go get yourself an alignment and enjoy being at whatever ride height you prefer and not destroying your tires!:fistbump:
sidenote:
I highly recommend you do a self-alignment to get yourself to a professional alignment shop in which case I'd recommend watching this video:
follow instructions from about 10:35, and then head on over to an alignment shop.
Links to products and parts mentioned:
K-Tuned Inner Tie Rods:
KTD-TRI-RCE-NEW Inner Tie Rod</br>EM2/EP3/RSX
Moog-ES2382:
https://www.amazon.com/Moog-ES2382-Tie-Rod-End/dp/B000C59VX0
(technically these are Celica tie rod ends, they just happen to fit the dc5 threads and are longer than our tie rod ends.
Tie Rod Lock Washer (53536-S5A-900):
https://www.acuraoemparts.com/oem-parts/acura-washer-tie-rod-lock-53536s5a900/?c=Zz1jaGFzc2lzJnM9cC1zLWdlYXItYm94Jmk9UzZNNEIzMzEwQSZyPTgmYT1hY3VyYSZvPXJzeC1oYXRjaGJhY2smeT0yMDAzJnQ9dHlwZS1zJmU9Ni1zcGVlZC1tYW51YWw=
Much of this info was obtained from these posts:
DIY: 0857 bracket install
Inner Tie Rod Removal Tool
Should be all the info for the day, if there is any concern regarding clarity feel to address it so I can make changes as needed.
#2 · (Edited)
Short Review
Fixed the toe problem I was having and got rid of the slop in the steering that I didn't even know I had.
The K-tuned has a little more weight to it and feels more durable than oem.
Side by side comparisons of the OEM and K-Tuned tie rods:
Top is K-tuned shortest and bottom is longest
Contrary to what I read on a post the K-Tuned is adjustable to become not just shorter but longer as well! :D
Feels amazing! Got rid of all the play in my steering, couldn't recommend more! :thumbsup:
#18 ·
:thumbsup:
sidenote: if you were taking your car to a normal alignment shop they may have a tough time figuring out how to adjust the tie rods. started at Firestone (which I usually go to because I have a lifetime alignment and they never had any problems before with them messing with my rsx with all it's modified suspension and requested camber specs because I'm cool with the girl who works the counter). However with the new tie rods, the guy legit tripped out and told me the tie rods weren't attached to the rack and recommended I get the car towed home. I was like wtf how do you think I got here lmao. Maybe he just didn't want to deal with it but I tried to explain to him how they worked but created an awkward scenario where I felt like he thought I was belittling him for not being knowledgeable of the tie rods and now I was doubting how he could even get the angle of the tie rods from underneath the car. Didn't want to deal with it since they technically aren't professionals in modified suspension alignments but on my way home decided to pass by a local Midas and since they were not busy I was able to fully explain the modification. they were also stumped for a minute but figured it out after a couple of minutes after looking over the suspension. also want to add that it was a little harder to explain to the "less than fluent in english" tech at the firestone where as the techs over at the midas were younger fluent speakers.
..and I'm off on a tangent, lol. long story short try a couple of shops if you have to.
#21 ·
I cannot get the passenger side inner tie rod out. The engine is really blocking me from getting the crescent on it at a good angle going in from the top. I'm not sure if I can get a pipe on it and have room between the tool and steering rack for it to actually turn.
Just asking for a bit more detail on this part for how you did the passenger side.
#29 ·
ok. worst case IF the locking washers aren't seated properly within that hexagon of the inner tie rod?
can these inner tie rods actually back out?
May or may not be likely, but I wouldn't risk it. Honda engineers would have done experiments and looked at data to see if they were a necessary part and they felt they were worth the cost added to the assembly process and final cost.
#31 ·
This is one of the best statements I have heard all year. The forum staff and the forum members have been putting in the extra work to make this an awesome place to be apart of.
We plan to continue expanding our stickies by asking members to contribute after assigning the topic(s) they have the most strengths in. The forum staff has been revising some of the older stickies, removing old ones were possible, and adding new sticky titles and provide content that is obviously important, useful, & note worthy.
I will continue asking for members if they would like to get involved with this. I have been lacking on finishing a basic/useful sticky on the DC5's suspension and procedural route choices to meet an owner's expectations.
