First of all this project is not for the faint hearted. I am a very patient person and this project tool all of it.
Here are some special notes:
Expect to spend a lot of time (for first timers) doing the front struts. If you have kids... even longer.
This is not an install guide. I lost my patience and did not bother taking any step by step pictures...
The coilovers on the front do not fit properly on the top strut plate bearing. The aluminium spring top provided by Ground Control does not sit on the bearing at all and is loose. I sent a message to Ground Control about this problem.
To fix this problem I used the OEM strut spring plate and rubber boot. I hope a part is made that actually fits.
See picture for final strut product with Oem strut plate.
Don't forget to align the strut plate properly, when installing completed product. It has an arrow that should point to the side of the car fender. Otherwise the plate will lock and unable to spin when turning. The spring will be stressed and noises will be heard.
Front Strut tooling:
Remove the top shock cover by cutting the first layer of metal that covers the strut at the specified 40mm by Koni. Once you do that, make a diagonal cut with the metal cutter. this will loosen the cap and will come out very easy. Worth the time.
<a href="http://photobucket.com" target="_blank"><img src="http://i45.photobucket.com/albums/f55/jmercado567/suspension2.jpg" border="0" alt="Image hosting by Photobucket"></a>
Then continue cutting the acutal strut at the specificed height by Koni.
Depending on your tools, you may have to perform the step below first to have more working space.
To be able to adjust the spring height adjuster you will need to use a metal cutting tool to remove the old spring assembly on the oem strut. Cut as much as possible, then repeatedly bend the 1.5 inch area to remove the metal piece or use a metal blade sawsall.
Removing the rear spring and shock:
Dont forget to use a pivoting (whatever the name) tool to reach one of the nuts. It is a pain to get in there even with the tool.
You do not have to remove the entire side panel to get to the screws. Watch for very sharp metal and panel edges.
When installing the rear coilover sleeve, the provided polyurethane sleeve is not thick enough to keep the sleeve from spinning when trying to adjust. Shim the urethan sleeve with a 2"x2" piece from the rear shock cover. Works great and you know it will not deteriorate.
Koni instructions were allright... it is funny how there are no words on their instructions. Just pictures... lol. The koni install was flawless and took the least time. Other than cutting the front oem strut it was pretty easy.
Oem shock removal:
On the first attempt the nut came off by just using an allen wrench and adjustable wrench. All others I had to loosen the nut counter clockwise first then I was able to use the allen wrench to keep the shock from spinning.
I cannot ephasize enough that you need a bolted down tabletop vise to hold the strut in place while you cut and drill the unit. It makes the job more tolerable. I did the first strut between my lets and they still hurt.
After the job is complete.
You will not be able to adjust the koni rears with the provided plastic cap. I cut mine till it fit, but was really hard to turn. Let me know if anyone has ideas for reaching the rears easily.
When I completed the project my words were... I hope this is worth the pain, cuts, bruises and cursing. The only reason I did this was for the supposed quality and durability of Koni and the non progressve springs from Ground Control.
I like the ride and now my front camber with just bolts is -2.2 (autox need) and the rear is slightly higher than stock. I will post pics of the car tomorow.
Oem shock removal:
