Currently I have a 03 ported k20a2 head and a stock 08 k24a2 block. I wanted to change my stock pistons to high compression and my stage 2 cams to stage 3 cams. Then I thought I might as well bore out my block.
1.Would this be beneficial to my set-up?
2.if so what size do i bore out to?
3.What size pistons do I buy?
4.I have to buy aftermarket K24 rods to rev higher correct?
5.Is there anything else i need to buy to bore out my block?
6.What is the highest compression i can run on this setup using 91 octane gas?
7.Would i still be able to use 100/110/e85?(if my city decides to carry it one day)
8.Anything else i should keep in mind?
